CCME + CUE interface lockdown
Here what I have:
Cisco 2600 series router with CCME and CUE in it.
Everything working fine except 1 thing:
If the router is reboot or after a random period of time for any reasons the ethernet interface that connect my call manager with my local network not responding anymore.
In the show cdp neibourgh---i see the switch and vice versa.
In show interfaces---the 2 int (the call manager 1 and the switch 1) are both link up with no errors.
But all my phone are rebouting and i can't ping from the CCME through local network..even the other way doesnt work.
The only solution i got so far is to go on console port of the CCME and shutdown it and re-enable it (even rebooting doesnt solve it)...after that everything is working perfectly. Its also a big problem cause my CCME is on a distant site so i can't get there as much as i want.
Can anybody help.
1 REPLY
Silver
Re: CCME + CUE interface lockdown
1) To check whether it is issue with the router or the network, try swapping the interfaces.
2) Also check for the errors in the switch side; it may go to 'err-disable' state when there are frequent changes in the link.
138
