CCME - Ephone Call Forward to IVR - does not work
We have a C2851 (IOS 12.4(1a)) with CCME. I?ve configured an IVR using Stonevoice. We wish have call going to the operator but if they don?t answer or are busy to CFNA/CFB from operator ephone to the IVR.
However when you call the operator phone, and it CF's to the IVR, the IVR does not answer. If you call the IVR extension directly it works fine. We have tried changing the transfer-system command from full-consult to local but this has had no effect.
The config is shown below.
Does anyone have a solution to this problem?
Chris
service script1 http://192.168.10.252/fw/Apps/IOSIVR/Server/TargetScript/script1.tcl
param msgLevel14 NONE
param selection33 8602
paramspace english index 1
param msgLevel15 NONE
param alert_time 15
paramspace english language en
param selection21 8046
param selection22 8047
param selection23 5285
param selection24 8605
param selection25 8604
paramspace english location http://192.168.10.252/fw/Apps/IOSIVR/Server/AudioFiles/
param msgLevel1 _Main-AM.au
param selection11 8601
param msgLevel11 _Members.au
param selection12 5283
param msgLevel12 _Suppliers_New.au
param selection31 5263
paramspace english prefix en
param selection13 5297
param msgLevel13 _GeneralPublic.au
param selection32 8602
param selection14 5263
dial-peer voice 1017 voip
description *** IVR DN5257 ***
service script1
destination-pattern 5257
progress_ind setup enable 3
progress_ind progress enable 8
progress_ind connect enable 8
max-redirects 5
session target ipv4:192.168.10.250
incoming called-number 5257
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
no supplementary-service h450.2
no supplementary-service h450.3
ephone-dn 1 dual-line
number 8600
label Reception1 (8600)
description 01159555255
name Reception
call-forward noan 5257 timeout 30
huntstop channel
no huntstop
hold-alert 15 originator
1 REPLY
Re: CCME - Ephone Call Forward to IVR - does not work
Chris,
Are the commands under the service menu for the router to talk to Stonevoice and play the ivr prompts ?
Can you try the following.
voice service voip
allow connections h323 to h323
codec g711ulaw
service script1
no vad
dial-peer voice 1018
session targtet ipv4:192.168.10.250
codec g711ulaw
no vad
Sankar
PS: please remember to rate posts!
173
