CCME Pin for users
Goodday all,
I have a customer who has a 7912 IP Phone in the Workshop. He wants his 8 employees to each have a PIN to login into the phone before making a call.Is it possible that one can configure more than one pin number on the ephone configuration? Or is there another way to achieve this request. At the moment they are using one pin for everyone to log in.
Thank you in advance.
Zipho.
Re: CCME Pin for users
Hi All,
Please, anyone with suggestions.
Thank you.
the pin command under CME is only used for toll-bar override. So if you have restricted calls to international or LD, during hours or after hours...people can login using the LOGIN softkey and override the restriction. Again i dont think 7912 supports this softkey. You may need a a 7940 or 7960 or better to support that softkey.
Hi Shanky.
Thank you for your response.
Again i dont think 7912 supports this softkey-I have configured it on the 7912 and that is what the customer is using currently on the IP Phones. We are using CCME 3.3. There is a "LOGIN" softkey and is working.
Can you have more than one pin under the same ephone config?
Thank you.
Sibusiso.
161
