Community Member
CCME Receiving calls problem
Working with CCME.
Some calls are received and terminated on an IP Phone. A call from another place to the same number is not working.
Here is the config and the debug isdn q931 trace for 3 calls, 1 failed, 2 success :
Re: CCME Receiving calls problem
I want to try somthing:
1. under the pots dial peer, put in the following commands:
incoming called .
direct
2. remove the translation profile for incoming calls (not sure why you have it)
3. Why is your extension length 2 while the incoming calls have 4 digits? If you do a show dial peer voice summary, you will see that your dial peers will be 99, not 0999. So, you either need to translate the incoming calls to remove the leading 2 digits, or change the extension length to 4 digits.
Community Member
1 I will test ASAP
2 The translation profile is to have the full dialed number because the Provider give 4 digits and the dialed number is 8 digits minimum
3 Under telephony-services, the dialin-pattern is on 8 digits so I need 8 digits for connecting the calls.
I will try to change my translation numbers to remove the first 2 digits instead of adding 4 digits.
Thanks for your help. I will update as soon as I have an answer.
Cheers
Charles
Community Member
I had the "incoming called ." and it works !!!
I don't know why I should had this. And also why sometimes the call match and another time it didn't match.
For 2-3 as I explained I do the translation to prefix 5557 to the number.
here is the display of the show dial-peer voice summary, you could 2 digits and 8 digits phone numbers...
dial-peer hunt 0
AD PRE PASS
TAG TYPE MIN OPER PREFIX DEST-PATTERN FER THRU SESS-TARGET PORT
20032 pots up up 55570995 0 50/0/16
20033 pots up up 96 0 50/0/17
20034 pots up up 55570996 0 50/0/17
20035 pots up up 97 0 50/0/18
20036 pots up up 55570997 0 50/0/18
20037 pots up up 98 0 50/0/19
20038 pots up up 55570998 0 50/0/19
20039 pots up up 99 0 50/0/20
20040 pots up up 55570999 0 50/0/20
20041 pots up up 70 0 50/0/21
20042 pots up up 55570970 0 50/0/21
93
