Community Member
CCME registers FXS but not dial-peers to GK
We have 7 CCME sites some of these ISR routers have FXS/Ports.
The question I have is why dont the Ephones register there numbers with the GK.
The FXS ports do.
Using dial-plan-pattern command we are not using the no-reg systax at the end .
So I would have thought that the dial-plan number would at least register with GK.
Is this IOS dependant
Community Member
Re: CCME registers FXS but not dial-peers to GK
The FXS port are usualy asigned a complete E.164 number hnece it registers automatically to the GK. As for e-fxs ports they are not physical entities but virtual ports.
Subhrojyoti
Community Member
So what does the no-reg e164 command do and the end of the dial-plan pattern command if thats the case.
Do ephone numbers ever register to GK
By default, gateways register all analog device e.164 addresses. They do not, however, register all dial-peers. If you want them to register dial-peers, try configuring the following.
on the CME:
voice service voip
h323
ras rrq dynamic prefixes
then on the gatekeeper:
gatekeeper
rrq dynamic-prefixes-accept
Please let me know if this helps by rating the post.
Michael
Forgot to mention the answer to your last question at the end of my last post.
The no-register command at the end of the dial-plan pattern or in a dial-peer creates exceptions to the globally configured, dynamic prefix registration directive I described before.
HTH,
Michael
Community Member
120
