CCME Ring Types
Is it possible with Cisco CallManager Express to add additional Ring Types for the phones. I am in the process of installing CME for a branch office. Their corporate office uses CallManager and they have been exposed to all of the different ring types which are available when using CallManager. I have found no information on adding additional ring types in addition to the default (Chirp 1, Chirp 2) with CCME and was just curious if it could be done. Thanks
Re: CCME Ring Types
Have just done this very thing.
You need to generate your own ringlist.xml. Needs to be exaclty the same format as the CCM one.
Copy this onto the flash of the router running CME.
Next copy the ring tones you require onto the router flash as well.
on the router config enter the following commands
tftp-server flash:RingList.xml
tftp-server flash:Ringtone.raw
The ringtone.raw is the name of each of the ringtones being used.
Reload the phone which will download the new ringlist and have access to the ring tones.
Hope this helps
Re: CCME Ring Types
Thanks, I'll give it a try
Silver
Re: CCME Ring Types
I do not think that the various ring types like CCM can be added to CCME. However, there are four types of alerting available when an incoming call apears on an IP Phone, ie, normal ring (single pulse for internal and double pulse for external calls), beep, feature ring (triple pulse cadence), and silent ring.
188
