Community Member
CCME TAPI with other 3rd Party CTI solution
I'd been tested out some 3rd Party CTI solution on CCME, but seems like there is some function that I could not run from the CTI software (with other PBX it's OK)
Some of the function are:
1. Trunk to trunk transfer.
This software can trigger a call using the client device (something like a call back function)
The PBX [TAPI interface] can make 2 calls, one to the user and the other call to the destination, after the call succeed PBX will patch the call
2. Call Transfer.
When we try to transfer a call, instead of fully transfer a call it do a consultation transfer.
Is there any setting in the router (we used 2801) that can trigger a full transfer from the software.
I already look through the setting and manual, and also try it out, but still have no luck
(telephony setting, transfer-system)
Please Advice,
Yamin Prabudy
120
