09-22-2006 08:59 AM - edited 03-13-2019 03:06 PM
Hello Guys,
I have 4 CCM 4.1 (one pub and 3 subs)and 2 Unity 4.0 servers. All servers are affected by virus and need to be patched. Could you please let me know what are th patches that I am going to need for this issue?
09-22-2006 09:56 AM
You can find the latest CCM operating system updates and service releases here:
http://www.cisco.com/cgi-bin/tablebuild.pl/cmva-3des
You can find the supported updates for Unity here:
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_unity/cmptblty/msupdate.htm
Also, make sure that you are running the latest CSA for CCM and Unity.
CCM CSA
http://www.cisco.com/cgi-bin/tablebuild.pl/unity3d
Unity CSA
If your systems have already been infected by the virus, you will definitely need to clean the infection.
Hope this helps. If so, please rate the post.
Brandon
09-23-2006 02:16 PM
Thanks Brandon,
The systems have a been infected. How can I clean the infection? Could you please help?
09-23-2006 05:48 PM
The specific answer depends on the infection. The answer in general is to use an antivirus software agent or an online scanning tool such as Trend Micro's Housecall.
Trend Micro Housecall
http://housecall.trendmicro.com/
The links below list the supported antivirus agents for use with Callmanager and Unity.
Callmanager Supported Antivirus
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_bulletin0900aecd800f8572.html
Unity Supported Antivirus
Hope this helps.
Brandon
09-24-2006 04:04 PM
Thanks Brandon,
Do I need to reboot the servers after applying patches?
Thanks agian,
09-24-2006 05:53 PM
That depends on the patch. More often than not, you will need to reboot.
Brandon
