CDR and Attendant Console
I do not have entries in the CDR of the Attendant CONSOLE pilot POINT. Could everybody tell me how to configure CDR to work with the Attendant Console?
Re: CDR and Attendant Console
you can try this:
You can pull the User reports from CAR tool [CDR Analysis and Reporting Tool]
Login to CAR tool > TOP N > By user extension
and this should tell you how many incoming calls were recieved by user on a specific extension.
Also, you can monitor the Attrndant Console parameters by Windows Perf Mon OR using Performance tab on RTMT tool.
You could always consider Queries directly from the DB.
285
