Bronze
CDR Dial Plan Configuration
This might be an easy, dumb question...but, when you configure the No of Digits, does that count any prefix digits? Like we dial a 9 to get out. Would I need to count that 9 or the CDR Dial Plan doesn't count discarded digits? Thanks!
Hall of Fame Super Red
Re: CDR Dial Plan Configuration
Hi Mike
There is no such thing as a dumb question.When configuring the CAR Dial Plan the 9 is ignored.Here is a link for CCM 4.1.3-CAR;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00803f526a.html#wp1092310
Hope this helps!
Rob
Bronze
Thanks for the quick reply! I have that document (and I'll admit I didn't read it word for word), but I didn't see it stated in there.
Another question...when you make a change to the dial plan configuration, will those changes just be in effect for any calls from then on out or if you run reports on previous calls before the Dial Plan Config changes will it work? Thanks!
Hey Mike,
No worries! The changes take place at midnight of the day they were implemented. I don't think the back dated reports will change.
HTH - Rob
Bronze
Does anyone know of any more detailed documentation on CDR & CAR? I ran a CAR report on Traffice based on extension by day of the week and I'm trying to match that up with a CDR report for an extension and it doesn't seem to match up 100%. I'm assuming it SHOULD match up, but it doesn't!
For example: In a CAR report, are Internal calls just incoming internal calls, outgoing or both?
Thanks!
177
