01-13-2006 12:54 PM - edited 03-13-2019 11:49 AM
We have some "legacy" DID numbers -- they enter Call Manager where a translation pattern sends them to the current, new number.
Is there someplace the call detail records I can find how often a particular DID (or particular translation pattern) was actually used? If these numbers are no longer in use, we could drop them when we switch carriers in the next month or so.
01-13-2006 02:03 PM
I've often wondered the same thing. No luck in finding a solution though.
02-14-2006 08:28 AM
I have the same requirement and have CM4.0(2a) and was wondering whether this situation had changed in later versions of Call Manager ?
01-28-2006 08:17 PM
Although there is no translation information in the CDRs, there is a service parameter which supposedly puts extra information into the traces.
Digit Analysis Complexity : This parameter allows the user to toggle between two modes; that is, StandardAnalysis and TranslationAndAlternatePatternAnalysis. The TranslationAndAlternatePatternAnalysis mode gives information about the Translation pattern and the Alternate matches in the CCM Traces while finding a match for a pattern. The valid values for this field follow:
-- StandardAnalysis
-- TranslationAndAlternatePatternAnalysis
This is a required field.
Default: StandardAnalysis.
Please rate the post if it helps
08-27-2007 10:23 AM
Is there anyway to do this in CallManager 5.1? My client is looking for the very same information
