02-14-2006 10:15 AM - edited 03-13-2019 12:10 PM
I have CDR running on my pub server. I get CDR data for most of my numbers, but I have a series of 10 numbers or so without any CDR info. When I pull a summary report, it comes up with zero calls. I know these numbers are making calls. Anyone else run into this?
02-20-2006 11:25 AM
If two users are associated with the same DN, then you might face such issues with CDR.
02-21-2006 08:10 AM
That is not the case here. The DN is only assigned to one number, just like the others that I checked on.
02-21-2006 02:53 PM
You might want to try a SQL query:
Go to Enterprise Manager --> Databases --> CDR, Select the CallDetailRecord table, right click on it and select Open Table --> Query.
Select a "search" type on the window like calling party number, under criteria choose the extension that you want to search.
Click the exclamation mark on the menu "!" to Run the query.
02-22-2006 07:12 AM
All of the calls are in there, but when I run the reports, it does not find any of that information. Actually, I've narrowed it down to use this one person now.
02-22-2006 07:28 AM
CallManager CDR reporting is very crude and unflexible. I use SQL queries to do CDR reporting. This link might be helpful http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801d71c5.shtml
02-22-2006 12:09 PM
If you have more than one server running like a subscriber and those ten IP phones are registered with it you need to enable CDR in the subscriber as well. Check service parameters under Services:
Name Parameter Value Suggested Value
CDR Enabled Flag* True
CDR Log Calls with Zero Duration Flag* True
