CDR Log - PRI not accepting calls
We have a PRI that handles our outbound local calls. It is registered to the CM (4.0) and use to work properly.
On the gateway it does show up/up on the interface.
The show isdn stat is as follows:
SAT-3845-R1#show isdn stat serial 0/0/0:23
Global ISDN Switchtype = primary-ni
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 0. Layer 3 output may not apply
ISDN Serial0/0/0:23 interface
dsl 0, interface ISDN Switchtype = primary-ni
L2 Protocol = Q.921 0x0000 L3 Protocol(s) = CCM MANAGER 0x0003
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x801FFFFF
Number of L2 Discards = 0, L2 Session ID = 53
Total Allocated ISDN CCBs = 0
The show isdn service is as follows:
ISDN Se0/0/0:23, Channel [1-24]
Configured Isdn Interface (dsl) 0
Channel State (0=Idle 1=Proposed 2=Busy 3=Reserved 4=Restart 5=Maint_Pend)
Channel : 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4
State : 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 3 3 3
Service State (0=Inservice 1=Maint 2=Outofservice 8=MaintPend 9=OOSPend)
State : 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2 2 2
I created a RG and a route pattern forcing a particular number out that PRI. I then looked the CDR logs and found the following:
destCause_value is 34. After some research I found that this means "the connection can not be established because no appropriate channel is available to take the call."
I am not sure where the problem could lie - is it the PRI or registration to the CM? The CM sees it as a registered gateway (there are multiple PRI's on the same gateway).
Finally, when I try dialing out that PRI I immediately get a fast busy.
Thanks in advance for any responses.
Jeff
1 REPLY
Re: CDR Log - PRI not accepting calls
if you do a debug isdn q931 do you see the same reason code for disconnect??
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
217
