CDR problem
i have a CALLMANAGER 4.1(2) and when i try to generate a call report or any other report a message appearse saying that data is available only up to the date .....(the callmanager installation date)at which there was no data at all.
so please help
1 ACCEPTED SOLUTION
Blue
Re: CDR problem
please verify a few pieces for CDR operation:
1) CDR logging is enabled:
ccmAdmin>service>serviceParameters>'ccmServer'>ciscoCallManager under the 'system' section.
verify CDR Enabled Flag = True
2) CDR Parameters are correct:
ccmAdmin>enterpriseParameters under the CDR Parameters section. (also verify your CDR location has disk space available)
3) CDR Insert is activated and running:
activated -
ccmAdmin>application>ciscoCallManagerServiceability>tools>serviceActivation to verify CDR Insert service is activated.
running -
ccmAdmin>application>ciscoCallManagerServiceability>tools>controlCenter to verify CDR Insert is running.
if CDR Insert service is running, perhaps a restart of the service may be helpful.
please see the following link for more CDR info:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00803f526a.html
Blue
Re: CDR problem
activated -
running -
Re: CDR problem
After verifying that the parameters are correct run the SQL queries:
In your publisher server, go to start > programs > SQL Server > Query
Analyzer > SQL Server: (local) ; Select "windows authentication" ;
click on "OK" > select the "ART" database from the drop-down menu. Run
the following queries (just copy and paste the following in the main
window, then click on the "execute query" icon):
delete from Tbl_Load_History
delete from Tbl_Dump_PkID
delete from Tbl_Error_Id_Map
delete from Tbl_Billing_Data
delete from Tbl_Billing_Error
delete from Tbl_Dump_CallDetailRecord
delete from Tbl_Dump_CallDetailRecordDiagnostic
Login into the CAR tool > go to the "system" menu > scheduler > CDR Load > Load CDR & CMR
Put the load duration in 60 minutes.
Restart the Cisco CDR insert and Cisco CDR Analysis and Reporting Scheduler services.
//Jorge
Re: CDR problem
This has happened to me a couple of times now.
I opened up a case wth tac and here is the document that outlines the issue.
It shows the 3 possible causes of it and how to fix each one.
My issue was cause 2 , and the solution was the same as what was posted above, when you run it, it will take several minutes to finish the query
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008056bd4e.shtml#cause3
246
