CDR Reporting Issue
Hi All,
I'm not able to get the most recent reports from the CDR Analysing & Reporting tool. It's throwing me an error saying "The data is available only till 27th Jan 2003. "
In the available reports I'm seeing one 'Available Report' whaich was mad on 27th Jan 2003. Is there any settings to be made ?
Jins
1 ACCEPTED SOLUTION
Re: CDR Reporting Issue
I had this happen to me. For some reason (maybe a reboot) the relevant services had stopped. Check the following services and start them if necessary:-
Start Menu>Programs>Administrative Tools>Services
Cisco CDR Analysis and Reporting Scheduler
Cisco CDR Analysis and Reporting Tomcat
Chris
Silver
Can you verify that CdrEnabled in Service -> Service Parameters -> Cisco CallManager Services on each server is set to "True".
Do you have any errors in the event viewer?
The value was set to TRUE. I didn't find any error in Event Viewer.
Jins
Silver
what callmanager version do you have? Did you upgrade the servers in january ?
Call manager version is 3.2.2c. I didn't have any upgrades during that time. The last upgrade was in November last year
Jins
Silver
Ok, so you have to figure out if the CDRs are not collected for some reason or not loaded to ART properly.
Could you verify there are records in C:\Program Files\Cisco\CallDetail\CDR on the publisher and in the SQL enterprise manager ->databases->cdr ?
what service pack are you running?how many servers in the cluster?Is CDR insert service running?
Sorry to jump in but I am having the same problem with the same version Call Manager. There are no records in the CDR folder you mention. Running the latest service pack myself and I only have 2 servers in the cluster and CDR service is running. If I need to start another message I will but I thought while I was at the same point I would
Silver
Do you have CdrEnabled set to true on both servers?
The Value is True.. Also I'm getting all the records in the CDR database. But thru the ART it's not coming
Jins
Silver
could you also post the C:\CiscoWebs\art\ErrorLog.txt file
Error Code = 1003
User Error Message =
System Error Message = java.sql.SQLException: [Microsoft][ODBC SQL Server Driver][Named Pipes]Specified SQL server not found.
Program Name = DbaDbConnect[connect]
User Id = admin
System Date = Sun Dec 01 18:47:30 GMT+05:30 2002
Error Code = 1003
System Error Message = java.sql.SQLException: General error
User Id = admin
System Date = Wed Jan 29 14:45:11 GMT+05:30 2003
This was the last events in the log... From Jan 29th I'm not getting any report . I'm Sorry for the delay.. I was on a long vacation.
Jins
Chris
The Cisco CDR Analysis and Reporting Scheduler was not running. Now I started that. But I still get the same problem
Jins
Hi All,
It worked for me. I restarted the Tomcat and ART Scheduler Services. Thanks a Ton..
Jins
156
