CG200 MGCP gateway and CCM 3.1(3) DID
how do you configure Callmanager 3.1(3) to support DID using VG200 PRI interface?
Thanks!
Chris
1 REPLY
Re: CG200 MGCP gateway and CCM 3.1(3) DID
You have two options you can use 12.2(2)xn and do mgcp that is explained in the link below.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122newft/122limit/122x/122xn/122xn2/ft_ccm.htm
Or you can do h.323 which is explain in the line below.
http://www.cisco.com/warp/public/788/AVVID/config_h323_ccm.html
The advantage of using MGCP is the gateway will failover to a secondary callmanager of the primary goes down and the calls will be preserved. With h.323 the calls will be dropped.
Hope this helps,
-Mckee
159
