09-11-2001 10:04 PM - edited 03-12-2019 12:33 PM
Is there a way to change the CLID on an incoming call on a PRI on a 2600? Thanks.
Manish
09-13-2001 06:36 AM
It is not possible on the IOS router to change the calling Number. If you are using Avvid then CM 3.1 allows prefixing of digits in translation patterns which may give what you want
09-14-2001 08:19 PM
Actually, yes you can alter the calling party's number in IOS, using the translation-rule feature.
