If you are referring to the default call handler (Opening Box), you can either program a subscriber (or DL) as the message recipient for this handler, or else you can enable the Alternate Greeting, set it to Blank, then set the after greeting action to Send to Greeting for your subscriber. This method would allow the subscriber to edit the greeting over the phone.
Scott Morgan
Cisco Systems TAC
