Changing DTMF to Out-of Band for ATA using SIP
How to change the AudioMode to get out-of-band DTMF?
The Audio Mode format: default format is 0x00150015.
Where 0015 0015 are the same audio settings for phone 1 and 2. My AS5300 "call history voice" shows a sipv2 call with inband DTMF.
"ATA parameters and settings" says:
bit 0 (mask 0x1): G.711SilenceSuppress: enable G.711 silent suppression (1)
bit 1 (mask 0x2): G.711Only: use G.711 only; do not use the low-bit-rate codec (0)
bit 2 (mask 0x4): FaxDetCED: enable fax CED tone detection (1)
bit 3 (mask 0x8): FaxDetCNG: enable fax CNG tone detection (0)
bits 4-5 (mask 0x30): DtmfMethod:
0=always inband (send and receive; don't send SDP info)
1=by negotiation (send SDP info, enable rcv, decode others SDP info, send depends on other SDP info)
2=always out-of-band (send SDP info, enable rcv, decode other SDP info, always send) (1)
any help would be appreciated
spencer
spencerw@dialdigital.com
1 REPLY
Re: Changing DTMF to Out-of Band for ATA using SIP
0x10151015 changes bits 4-5 to value "2" OR 10 in binary where 0001 0000 0001 0101 is the new setting
118
