04-02-2004 06:34 AM - edited 03-13-2019 04:31 AM
Has anyone come across a way to change the Cisco CME logo on the 7912 phones, running under CallManager Express, to something diferent (company logo in this case). Call manager is version 3.1.
04-09-2004 06:56 AM
Try this link. It is useful.
Creating Idle URL Using Graphics on Cisco IP Phone
12-01-2004 02:30 AM
I have the same problem, have u ind any solution ??
thx
03-14-2007 12:37 PM
The link is not useful since it is for services display purposes, not for change the screen logo.
Does anyone know how to chang the logo on the 7912G phone with Call Manager Express?
Thanks.
03-14-2007 01:11 PM
This is the guide by our fellow cisco CSE gogasca.
Rememeber that every time you change the logo again, you must increase the numeric ID used in both the bmp2logo command and the configuration file.
03-15-2007 02:33 AM
Sorry, but this is the guide for Call Manager, NOT Call Manager Express.
In CME you can't provide the provisioning URL.
03-15-2007 12:58 PM
Who says you can't change the provisioning URL for a Cisco IP phone using Call Manager Express? You absolutely can. You can also configure CCME to use an external tftp server and use a different provisioning xml file per phone. Details are provided in the CCME 4.0(3) docs:
03-15-2007 01:12 PM
The process for changing logo is conceptually the same, Using CCME you will need to include "gkdefault.cfg" in a "tftp-server" configuration.
03-16-2007 12:27 PM
Any of the configuration guides above is not valid for CME.
I've opened a TAC case.
I'll tell you if can make it work.
Thanks anyway.
03-16-2007 02:34 PM
No, the guides are valid. The process of converting the logog and creating the config file is made on a PC. Then you use a TFTP server of your choice to load the config file and the logo into the phone.
Many many people has done that already with CCME.
04-02-2007 03:10 AM
Please, send me the contacts that make this work with tath method.
04-02-2007 04:05 AM
Same links as previously indicated:
04-04-2007 07:13 AM
Same useless guide since doesn't work with Call Manager Express.
04-04-2007 11:52 AM
Davidfloria you are incorrect.
As I mentioned before the guide is valid because the procedure is independent form the platform used. It is all about preparing image file, binary file, and put them on a TFTP server, that can be CCM, CCME, or third-party.
Now if you was to tell us what exactly your problem is, or what is not clear to you, we would be able to help you better.
03-16-2007 06:30 PM
i am sure that the below link will help you to customize the logo on 7912, 7906 phones, i personally did it this way
