Community Member
Cisco 2851 and NEC Fusion 2600
I am designing a Call Manager system where the Call Manager servers and the gateway will be located in area A and the users in area b. the gateway in area a will a an e1 trunk to a NEC Fusion 2600 PBX . I was wandering if anyone has had any experience on this and if they have any pointers.
Thanks in advance
Paul
Silver
Re: Cisco 2851 and NEC Fusion 2600
The NEC Fusion protocol is implemented by the 5300, but not the 26/36. You have to use T-CCS with a 26/36 if you want to run NEC Fusion or NEC CCIS.
Community Member
Thanks for the response. What is the T-CSS and is it compatible with a cisco router. I am using a cisco 2851XM router and an E1 PRI cable to connect the two. I have done something similar where the PABX sent DPNSS siganlling which we converted to QSIG using a westell converter and the sent it into a 2651XM using E1 PRI with QSIG signalling.
300
