Cisco 3640 + MGCP - incoming call
Hi.
I try make work MGCP gateway.
Thanks to Dave, I can make calls outside now.
But when I call inside - call is dropped...
I hear one normal signal, then busy signal...
If it was H.323 it is clear... we do destination pattern for all calls... But what about FXO and MGCP with incoming calls.
If we use DID ... it is clear too....
But where we can configuring rules for all incoming calls or calls for this on fxo port with MGCP....?
Thanks in advance.
Re: Cisco 3640 + MGCP - incoming call
Sorry...
I figured out...Now it works...
I'm struggling with the same problem. How did you fix it?
Dave
Sorry... I did not remember... but it was something simple and stupid ... like other calling search or partition....
Nothing special....
I should wrote down all my mistakes... But I did it only for something really hard....
Check that gw are in the same Calling space and partition with you phones. I believe it was it.... It is typical symptom that you can receive calls but cannot place it.....Let me know if it help. :-))
138
