cisco 3640 with e&m intervaces codec question
I have a c3640 runnning 12.2(12a)with 3 e&m VIC's and connected to a PBX.
all voice port's are configured the same:
voice-port 2/0/0
playout-delay mode adaptive
no comfort-noise
timeouts initial 5
timeouts interdigit 5
operation 4-wire
type 5
voice-port 2/0/1
no comfort-noise
timeouts initial 5
operation 4-wire
type 5
voice-port 2/1/0
no comfort-noise
timeouts initial 5
operation 4-wire
type 5
voice-port 2/1/1
no comfort-noise
timeouts initial 5
operation 4-wire
type 5
voice-port 3/0/0
no comfort-noise
timeouts initial 5
operation 4-wire
type 5
voice-port 3/0/1
no comfort-noise
timeouts initial 5
operation 4-wire
type 5
I have no successfull call on voice port 3/0/0 and 3/0/1...
when I do show voice dsp, the coded seems different on those lasr 2 ports:
c3640voice#sh voice dsp
DSP DSP DSPWARE CURR BOOT PAK TX/RX
TYPE NUM CH CODEC VERSION STATE STATE RST AI VOICEPORT TS ABORT PACK COUNT
C542 001 01 g723r63 3.4.52 IDLE idle 0 0 2/0/0 NA 0 133293/1713
7
C542 002 01 g723r63 3.4.52 IDLE idle 0 0 2/0/1 NA 0 165511/1782
9
C542 003 01 g723r63 3.4.52 IDLE idle 0 0 2/1/0 NA 0 24744/15023
C542 004 01 g723r63 3.4.52 IDLE idle 0 0 2/1/1 NA 0 133601/1565
9
C542 005 01 g711ulaw 3.4.52 IDLE idle 0 0 3/0/0 NA 0 51/58
C542 006 01 g711ulaw 3.4.52 IDLE idle 0 0 3/0/1 NA 0 0/33
6
of course dial-p v pots using the different ports are configured the same and PBX engineer is confirming config on hi side is identical for all PBX interfaces: i.e
dial-peer voice 13 pots
destination-pattern 33...
port 2/1/1
Can some on tell me why i am seeing codec difference between those ports?
I am expecting also to have g723r63 on port 3/0/0 and 3/0/1 ?
please advise and if any further info is needed please let me know.
Best regards,
ahmed
Re: cisco 3640 with e&m intervaces codec question
any suggestion/help ?
Thanks.
Silver
Try changing the codec complexity for the DSP's used by port 3/0/0 and 3/0/1. In the config mode enter the commands
voice-card
codec complexity high
You might want to do a show diag to get the corresponding voice card number
Also configure the codec in the outgoing dial-peer for these ports using the "codec" command
Anup
This is not working.
checked further and it's only for digital voice cards that you can set the complexity to high or medium.
I found also that C542 technology is medium complexity and supports one voice or fax-relay call per DSP.
Also the codec is already configured to g723r63 on all outgoing dial-peer.
any more suggestions ?
Thx
147
