Cisco 3660 with E1-PRI as MGCP Gateway
I Have a router 3660 with a E1-PRI card, IOS 12.2(2)T1, CallManager 3.1(1).
I have configured the router as MGCP Voice Gateway both on the router both on CallManager.
From CM I can see the E1-PRI card registered, but when i try to make a call to the outside or receive a call from the outside, I can see (on the router) that there is no connection between the two.
Does anyone know if it's a configuration problem or IOS version problem?
Re: Cisco 3660 with E1-PRI as MGCP Gateway
The version of code you are using on the 3660 does not support mgcp pri with the call manager. The code that you need is 12.2(2)XN. I think it is suppose to be out by the end of October.
Thank you,
Many thanks for your help.
I will wait for this version.
many thanks
133
