Cisco 3700 VoIP connection to a D4 Channel bank with FXO connections
Has any one got this to work?
ATA186----CIsco 3700-------Adtran 750
FXO channel --Nortel
DMS10 Line
Linecard
If so How?
Silver
Re: Cisco 3700 VoIP connection to a D4 Channel bank with FXO con
Haven't tried it but try using T1signaling on the 3700 router. You can configure dial peers on the ATA.
Silver
Assuming the ADtran uses E&M wink start, something like this would work -
controller t1 1/0
clock source internal
ds0-group 0 timeslots 1-24 type e&m-wink-start dtmf dnis
dial-peer voice 1 pots
destination-pattern 9
port 1/0:0
The ATA would dial 9 plus the rest of the numbers, the call would be directed to the 3700 gateway and would go out via the CAS trunk to the ADTRAN and to the PBX.
The ATA would use the gateway field to point to the IP address of the 3700 router.
272
