Cisco 3745 to CallManager without MGCP
I have 2 PRI in spain and I try to configure my router to connect to Callmanager.
3745 with NM-HDV-2E1-60
IOS : c3745-advipservicesk9-mz.123-8.T5.bin
When I try to connect on one of the 2 PRI, the router doesn't relay to callmanager.
I attached the config and the debug...
I have two other questions, can I use on the same router, toi connect to :
a sip server, a gatekeeper and a callmanager?
Thanks, Regards
Bronze
Re: Cisco 3745 to CallManager without MGCP
You make the router as H.323 gateway and connect to the CallManager.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094636.shtml
Thank you for your answers.
Is your ip phones having full 8 digits configured as DN ? Try to match the dial-peer for voip in the router configuration, as ........ (8 dots) rather than T and see if that helps!
211
作成コンテンツを作成するには してください
