Cisco 3825 Voice Gateway Losing Configuration After Recovering From SRST
Hi all,
I've notice this issue happening when the VG router recovers from SRST thus downloading the configuration from the Cisco CallManager. I'm just wondering is the a way to set the Call Manager to have the settings below. Thank in advance.
---- Current / Initial config ----
controller E1 0/0/1
framing NO-CRC4
pri-group timeslots 1-16 service mgcp <<<<<<<<<< We had to split the timeslots as the router doesn't have enough DSP ports
controller E1 0/1/0
framing NO-CRC4
clock source internal
pri-group timeslots 16-31 service mgcp
interface Serial0/0/1:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
interface Serial0/1/0:15
no ip address
encapsulation hdlc
no logging event link-status
isdn switch-type primary-qsig
isdn protocol-emulate network
no cdp enable
---- After recovering from SRST & configs downloaded from CCM ----
controller E1 0/0/1
framing NO-CRC4
controller E1 0/1/0
Hall of Fame Super Gold
Re: Cisco 3825 Voice Gateway Losing Configuration After Recoveri
Appears that is a bug.
IOS used? can you upgrade and try again?
Currently running IOS 12.4(6)T6. I don't think it's a bug but more of the Call Manager settings as the router will download a config once it has established a ccm connection. Hope this helps
427
