Cisco 5300 and FAX receiving
I am trying to receive FAX on my 5300 gateway, FAXes are coming from SIP in G711 codec with inband DTMF,
Cisco receive call on VOIP dial-peer and send it to POTS:
dial-peer voice 1200 voip
huntstop
incoming called-number 2307602T
no modem passthrough
codec g711ulaw
dial-peer voice 1201 pots
huntstop
destination-pattern 2307602T
no digit-strip
port 0:D
forward-digits all
prefix 5
Then I have T1 0 connected via cross over cable to T1 2 on same cisco:
dial-peer voice 1400 pots
huntstop
application on-ramp
incoming called-number 52307602T
information-type fax
no digit-strip
direct-inward-dial
port 2:D
forward-digits all
dial-peer voice 1401 mmoip
huntstop
application fax_on_vfc_onramp_app out-bound
destination-pattern 52307602T
session target mailto:efaxrelay@IP-ADDRESS
mdn
dsn success
So.. actuall fax receiving happening on dial-peers 1400 and 1401 sends it to email server. It works just fine on short faxes but overal quality is bad.. some faxes get corrupted, in case of multipage faxes some pages usually in the middle of the fax get corrupted.
twoquestions: is what i am doing make any sense and second question is there any way to limit cisco to receive faxes on not more then 9600 rate ?
Thank you
1 REPLY
Silver
Re: Cisco 5300 and FAX receiving
I think you may be running to bug CSCdu76098, fax relay is broken when modem passthru is configured.
If you are under T.38 Fax-relay broken when using IVR Session Application, try this bug - CSCdv27502.
This URL should helps you It speaks about Voice Over IP - Per Call Bandwidth Consumption:
http://www.cisco.com/warp/public/788/pkt-voice-general/bwidth_consume.html
This URL speaks about Troubleshooting Fax Applications:
http://www.cisco-secure.net/univercd/cc/td/doc/product/software/ios123/123cgcr/vvfax_c/voipt_c/vts_fax.pdf
116
