Cisco 7960 Phone register CM problem
I have two Call Manager 7835 Server
one Cisco 7960 Phone
CM1 and CM2
the CM-cluster have CM1 and CM2.
CM1 is pulisher server and CM2 is subcriber server
I set my CM-group is CM2 highest priority than CM1.(default)
the device pool is default set CM-group (default)
my Cisco 7960 can register CM-cluster,
but It register CM1 not CM2,why....
is my CM group worng or ...
How can I do, use CM2 not CM1....
CM version is 3.0(9).....
  • Other Collaboration Voice and Video Subjects
Silver
Re: Cisco 7960 Phone register CM problem
Is "Default" the only device pool you have?If it's not can you go to System->Device defaults and verify 7960 is using the default device pool for autoregistretion?
In the CM Group configuration do you have the following group order
CM2
CM1 ?
Can you also verify if the auto-registration callmanager group box is checked on the CM-group configuration page ?
First, Thanks your reply,
my device pool just have default setting,
I'm not use "Device default" command for my IP Phone use.
in my CM group is use
CM2
CM1
is correct...
I have use auto-registration check box at my call manager group.
do I check any setting or ..
regards,
Shawn
Silver
I dont see any configuration issues actually, if all you have done is giving highest priority to CM2 in the Default callmanagre group it should work.
Are you sure your CM2 is up and running?
When you go on the ip phone to settings->network configuration do you see
Call Manager 1
your cm1-ipaddress Active
Call Manager 2
your cm2-ipaddress Standby ?
CM2 is running,
Call Manager 1
CM1 ip address Active
Call Manager 2
CM2 ip address Active
in fact,
I have 20 IP Phone.
all of Phone setting the same CM-Group
now.
14 IP Phone register to CM1
6 IP Phone register to CM2.
how can I do,
we have restart CM service and TFTP service, but no any change.
regards,
Shawn
hi shawn.
since this is the way it is supposed to work for a redundant cluster, and i know that it works, i believe you should check the publication/subscription - relation between the two sql-servers. until the subscription does not work correctly, the registering -process to the subscriber will not work.
there is a document on how to re-establish the replication. check
http://www.cisco.com/warp/customer/788/AVVID/recreate_subscribe_database.html
good luck,
gerhard
Thanks your reply,
I have check my publication and subscription server,
the relation is good,
I saw you suggest the document.
CM-Group is
CM2
CM1
I have 15 IP Phone set to CM-Group,
but just have 8 IP Phone to register CM2
another 7 IP Phone to register CM1,
the same setting for all of IP Phone, so ...
where is my problem ...
regards,
Shawn
Silver
So everything is working fine and you just want a half of your phones to register to another server?
add another callmanager group then with opposite servers order and another device pool to include the new group and assign the phones you want to this device pool..
Yes,
my default device pool use CM1 and CM2
CM1 is active
CM2 is standby.
I want use CM2 to control my IP Phone and Voice Gateway,
but I don't want to add new Device Pool,
so I direct change my CM-Group to CM2 then CM1,
Is the command worng or...
regards,
Shawn
145
