Cisco 7960G and Firmware Upgrades
r.drummond
is there a certain upgrade path i have to take to upgrade the SIP firmware on my 7960G. i got the phone, and upgraded it to 6.1 successfully, then i went and tried to upgrade to 7.5, and all the phone would do is come up and say "Protocol Application Invalid" I was able to revert back to 6.1 and salvage the phone. i was just wondering if i had to go through each revision until i get to 8.2?
thanks.
-Rob
Aaron Harrison
Hi Rob
See this link:
http://www.cisco.com/en/US/products/sw/voicesw/ps4967/products_upgrade_guides09186a008022a968.html#wp1053736
The table states that to go from SIP 5 or 6.x to 7.x you need to do procedure D, and the '2' footnote says you can't go straight to 7 but need to go to 6.3 first.
Clear as mud?
Hope this helps..
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
ok, well i have upgraded to 6.3, when i tried to go to 7.6, i got the Protocol Application Invalid again. I went back to 6.3 again, and tried to apply 7.0 and work from there. I got the same result. i am just confused as to why it is not working. i do have a question. when i look in the OS79XX.txt file i see P003-07-0-00
should that read P0S3-07-0-00 to reference the SIP version?
