Community Member
Cisco Agents goes to Not ready state
I have use IPCC ver:4.0(5) SR01ES09_Build095.
We have encountered that our cisco agents automatically change state and it will goes from log-in state to Not ready state.
what was the solution where i have to check the logs.
regards
Salman
1 REPLY
Re: Cisco Agents goes to Not ready state
Hi Salman-ahmad,
This could be the way you have your agents or CSQ configured, you can configure IPCC to have them to automatically goto Not ready or stay in ready. Have you check your system parameter's?
Under RMCM Subsystem, click the resource link on the left hand side,
there is a "automatically Available" radio box you need to select.
Otherwise you maybe hitting this bug.... Are these your symptom's?
CSCsf11662 Bug Details
Agent goes to Not Ready after making Outbound call from Ready state
Symptom:
Agent makes outbound call from ICD extension (to a non-ICD extension), when
the agent finishes the call, they go into Not Ready state when they expect
to be returned to Ready state.
Conditions:
- Cisco Customer Response Solutions (CRS) 4.0(3)
- Agent makes outbound call from ICd extension whilst in Work state (after just finishing an incoming ICD call).
- Agent places the outbound call on Hold at some stage during the call.
Workaround:
If the above scenario occurs, Agent needs to manually change to Ready state.
HTH, Please rate if so
Justin
156
