11-10-2008 08:19 AM - edited 03-13-2019 05:49 PM
Ladies and Gentlemen:
I am running Call Manager 4.1(3)sr3a at one of my locations with Unity 5.0(1.0) and Exchange 2003.
This is a SIP newbie question.
What Cisco and other branded phones work well with SIP? I am talking about âhard phonesâ at this point.
I am getting some conflicting information.
Thanks, Tom
11-10-2008 08:28 AM
are you planning to use them with 4.X?? i mean, you want to register them to CCM???
because SIP support is only 5.X and above, previous versions require a separate SIP server and a SIP trunk to CCM for this to work
java
if this helps, please rate
11-10-2008 10:00 AM
HTH, we are going to 5.x in the first half of 2009. Can SIP be run in a mixed environment? Or is it one or the other?
Yes, it would be nice to register with CCM 4.x.
I was hoping to setup something in a lab environment to CCM 4.x. It maybe more trouble than it is worth.
Thanks Again, Tom
11-10-2008 10:29 AM
HTH = Hope This Helps haha
yes, you can have both SIP and SCCP in 5.X and above. Windows based CCM only supports SCCP for phones and as i mentioned, the only way to have this is to have a SIP Proxy, Registrar, Etc separate and create a SIP trunk to communicate between systems.
java
