Cisco ATA problem
I have a problem with Cisco ATA 186. I used it without any problem but sudenly it went crazy. When I use voice menu it allways prompts for PSSWD. I tried factory reset but even then it asks for password so I cannt use that. I cann't configure static IP adresses and ATA doesn' want to accept address via DHCP. So as you see I can not do anything. Really strange!
Any ideas!
Silver
Re: Cisco ATA problem
Lift the handset and press the Function button located on top of the Cisco ATA 186.
Step 2
Enter the IVR menu number for the parameter that you want to configure or the
command that you want to execute; then, press the pound key (#).In your case Reset Password = 673673263372466#
Step 3
Follow the applicable prompts.
Step 4
When you have finished, make sure you press 3 to save your changes.
Step 5
Hang up the telephone. The Cisco ATA 186 resets.the function button will fast-blink when the reset is complete.
Thank you for response, but id didn't work because it is invalid entry. Any other idea?
TNX
195
