Cisco Call manager using PSTN Line
Eventually i have purchased
Cisco Router 2620
NM-2V
Vic-2fxo Card
Can you please let me know how to configure the gateway to use PSTN line with my SCCP Phones which is already registered with call manager 4.1.2
Please provide me the configuration
Re: Cisco Call manager using PSTN Line
It depends on the gateway protocol you want to use.
Here is a document on MGCP gateway configuration:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008009428e.shtml
Here is one for H.323 gateway configuration:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094636.shtml
Brandon
Firstly thank you for the reply
I have followed your instructions still unable to registered gateway through call manager. Here is the cisco 2620 config info.
melbournegroceries#sh running-config
Building configuration...
Current configuration : 917 bytes
version 12.1
service timestamps debug uptime
service timestamps log uptime
hostname melb
enable secret 5 $1$gBy6$c0.PnhoPtkNCQ4GJqKOr01
enable password voip
ip subnet-zero
no ip finger
voice-port 1/0/0
voice-port 1/0/1
voice-port 1/1/0
voice-port 1/1/1
dial-peer voice 4 pots
application MGCPAPP
port 1/1/1
dial-peer voice 3 pots
application MGCPAPP
port 1/1/0
dial-peer voice 2 pots
application MGCPAPP
port 1/0/1
dial-peer voice 1 pots
application MGCPAPP
port 1/0/0
interface FastEthernet0/0
ip address 192.168.0.120 255.255.255.0
speed auto
full-duplex
interface Serial0/0
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.0.121
no ip http server
snmp-server community yes RO
line con 0
transport input none
line aux 0
line vty 0 4
password voip
login
no scheduler allocate
end
melb#
melb#sh version
IOS (tm) C2600 Software (C2600-IS-M), Version 12.1(5), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Wed 25-Oct-00 11:43 by cmong
Image text-base: 0x80008088, data-base: 0x80CAC644
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
melb uptime is 1 hour, 7 minutes
System image file is "flash:c2600-is-mz_121-5"
cisco 2620 (MPC860) processor (revision 0x102) with 53248K/12288K bytes of memor
y.
Processor board ID JAD042701EE (1286926306)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
4 Voice FXO interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
melb#
Please advice something thanks
Make sure that the MGCP domain name matches the router hostname exactly. This is case sensitive. Also, I don't see the MGCP configuration on the router as described here:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008017787b.shtml
You will need the following commands:
mgcp
mgcp call-agent [CCM IP Address]
ccm-manager mgcp
ccm-manager redundant-host [Backup CCM IP Address]
ccm-manager config server [TFTP IP Address]
Brandon
When i type mgcp command its not accepting.
melb(config)#mgcp
% Invalid input detected at '^' marker.
melb(config)#
What could be the reason?
Thanks For your reply
I just noticed from your show version command that the IOS version you have installed does not support voice.
Brandon
Thanks for your reply
I didnt understand "feature set you have installed (IP Plus) does not support voice"
You mean to say configuration is incorrect or the device which i am using is not supported.
What do i do to support voice?
Your device is supported. You will need a minimum of 12.2(11)T (IOS Version) to support MGCP.
Brandon
130
