Cisco CallManger 3.1 installation issues
I installed Cisco CallManager 3.1 on Windows 2000 5.00.2195 SP2 with SQL 7.0 SP4. I'm having a problem with the following services starting; Cisco CallManager,Ciso CTIManager and Cisco RIS DataCollector. The event viewer for the application log is saying;
1 - Source CallManager: Error: Database connection error..
2 - Cisco MOH Audio: Error: SDIControlLayer for Cisco MOH Audio Translator application is attempting to connect to Database..
3 - Cisco IP Voice Media: Error: SDIControlLayer for Cisco IP Voice Media Streaming App application is attempting to connect to Database..
Any ideas what it could be and where to even begin to debug the problem?
1 REPLY
Re: Cisco CallManger 3.1 installation issues
Hello Gregg,
First, are you using a Cisco approved server which has been installed from the STI scripted installation procedure? Second, did you have an active network connection to a switch (or hub) when you did the install? I have had problems with CallManager connecting to its databases or processes when doing a manual install or simply forgetting to patch to a switch.
Bob
BTW The solution in the case if not having a good network connection was to start over. I do not know if there is a quicker fix.
172
