Cisco IP IVR product Key
Hi ,
I have downloaded and installed this following software : icd-ivr-aa-ffr.2-2-3a.exe with this product key of Apps 2.2 find in this URL.
http://www.cisco.com/warp/public/788/AVVID/productkey.html
After finishing installation I found only Cisco IP AA, IP EM, IP ICD and IP WF SDK.
when I have retried installing Cisco Ip IVR with this product Key (( KARB KEGB FDYR OVYW)), I Have had this message:
Cisco Installation Wizard
Cisco Extension Mobility has been previously installed. Are
you sure you wish to reinstall the product?
Yes No
So, there is it somebody who can send me a product Key of Ip IVR if this is possible, Please help :-(
Thanks in Advanced
Best Regards
1 REPLY
Silver
Re: Cisco IP IVR product Key
That appears to be the correct key. I would try uninstalling a reinstalling clean and if you end up with the same results you'll probably need to talk to someone at Cisco.
181
