Cisco IP phone 7960+ATA 186
welcome All!
There is a CM of version 3.1 and ÀÒÀ 186. On CM ÀÒÀ it is registered as Í.323 the device. I call from phone Cisco 7960 on ÀÒÀ - there is no ringback. With ÀÒÀ on the phone 7960 - ringback ok. In what problem, help to understand. It is thankful in advance
  • Other Collaboration Voice and Video Subjects
Bronze
Re: Cisco IP phone 7960+ATA 186
Hi ,
there is a field on the ATA called "ConnectMode".
Make it to: "0006e011"
Good Luck
Mehmet
Can you say, what does Bit 4 (0x10) mean ?
It's not documented.
That will fix your problem, but I suggest running the ATA 186 and CCM with SCCP. The support just came in the 2.12 release of the ATA software. The ATA emulates a 7960 in CCM 3.0, 3.1 and is it's own device in 3.2. You must at least be running 3.0(10) or later.
Here are the release notes for the 2.12 version of software for the ATA.
http://www.cisco.com/univercd/cc/td/doc/product/voice/ata/ata186/ata186rn/186rn21m.htm
Thank you,
-Mckee
133
