05-13-2002 09:49 AM - edited 03-12-2019 06:47 PM
Anybody have any experience about the SDK ? when I want to use the samples that need access to an external url I obtain the next errors:
Error:not to able to access service URL
Service failed
Error: An exception occurred
Thanks.
05-13-2002 10:37 AM
Is the phone getting the proper default gateway and ip addressing info from the dhcp server? Use a packet sniffer to see what url is being requested by the phone and exactly what reply is coming back.
A helpful hint on the 79xx phones - you can run the packet sniffer on a PC plugged into the pc port of the phone and see all of the phone traffic.
06-13-2002 09:45 AM
I have found that most of the samples have to be edited to work properly on my test system. The URLS are generally not right, usually just because i installed it in a different path than the asp file is written for.
Which app are you trying to use?
06-17-2002 11:51 PM
I'm trying to use two app: "weather from CNN.com" and "world clock". In those apps I've changed the path, but I'm not sure if you have to change anything else.
