Cisco OS 2000.2.7 does not support MCS 7825I1 ?
Hi Pros,
I have a new installation coming up of CCM 4.1.3 & Unity 4.0.5
Seems Cisco has sent wrong set of OS Cds for CCM. The Server is a IBM make (MCS 7825I1) with Prescott 3.4 CPU & 2GB RAM alongwith 2 * SATA 80GB HDD.
When I insert Hardware Detection CD for 2000.2.7 it says "This OS version does not support the detected server. Remove the disk and press any key to reboot.
My BoM says:
CM4.1-K9-7825= SW CallMgr 4.1, MCS-7825 2
MCS-7825-I1-IPC1 HW Only MCS-7825-I1 with 2GB RAM
and SATA RAID
Can I install like this - Run IBM ServeRaid, Prep server, Insert Win2k cd, then after install run OS Upgrade 2000.2.7
Will this work?
Pratik
1 ACCEPTED SOLUTION
Re: Cisco OS 2000.2.7 does not support MCS 7825I1 ?
Yeah you need 2000.4.x discs.
I believe this server requires OS 2000.2.7a
I have 2000.2.7a Cds which dont work. Please understand the model is with 3.4Ghz CPU. What I heard from PDI is 2000.4.1 will have to be used.
i am not sure why the CPU speed should matter.......
I don't know what to say, if you have the "a" hardware detection disk, this should work. I have never had a problem once i had the right media so i will step aside and wait to see if someone else can help.
Steve
Hi Sankar,
Thanks for the info. Tell me something, if I downgrade the BIOS on the server, would it work?
Pratik
126
