Cisco PA 1.4.3 installation
I am trying to install Cisco PA 1.4.3 on a server. The PA will be integrating with CM 4.02aSR2a which is already installed and in production.
I am at a stage where you specify CM hostname (or ip address) and windows username and password. I get an error message saying, the "Callmanager you have is not a Publisher".
There is only one CM server and it is a publisher. Thoughts..??
Sankar.
PS: The CM hardware comp. matrix, lists PA 1.4.4 and 1.4.5 as compatible with CM 4.02a. So do I need 1.4.4 or higher to make it to work ?
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/ccmcomp.htm#CCMUpgradeCaveats
1 REPLY
Re: Cisco PA 1.4.3 installation
Never mind, I put the name resolution on Lmhosts. I had to set it on hosts file, and the wizard continues to install PA>
91
