Community Member
Cisco Unity System Greeting
when a subscriber record their first and last name, but no greeting. callers here "sorry first name last name is not available, record your msg after the tone....."
Is it possible to edit this system greeting "sorry..." or record a custom greeting and put it in the same location as the system greeting.
My customer wants a standard greeting with one voice that announces the subscriber name during the greeting, but does not want to record the greeting 200 times for each subscriber.
Can this be done?
Re: Cisco Unity System Greeting
All these files are in the Commserver folder. YOu should be able to re-record them.
---Edited---
I checked through a Cisco Unity server here in mhy lab..In CommServer\Localize\Prompts\ENU\G711\AvPHGreet folder, you have files by the name,
AvPHGreetENU018.wav and AvPHGreetENU019.wav.
the first wave files says, sorry.
the second wave files says "is not available".
So it looks like its taking the person's recorded name and sandwitching this wave file between wave files 18 and 19 and play it out. I am not sure how you can tell Unity to not play the name in between.
Community Member
I will give it a try
279
