Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Cisco VoIP Gateways and Lucent VoIP Solution Interoperability
We have a VoIP network based on Lucent MAX6000 Gateways and Multivoice Access Manager Gatekeeper
We try to use cisco AS5300 in one of inclusion areas of our network, Registeration process with Lucent's Gatekeeper done, and calls from MAX6000 to AS5300
established but after a period of time,appproximately 360 seconds,the outgoing call was drop,But MAX6000 to MAX6000 calls have no problem.
I searched on Cisco Website and read so many documents but I didn't find any comment.
Re: Cisco VoIP Gateways and Lucent VoIP Solution Interoperabilit
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
I also have the exact same problem with some 2600's. This seems to be a common problem between the two platforms.
117
