Community Member
Cisco VoIP SNMP monitoring?
One of my clients would like detailed monitoring and reporting on their Cisco IPT/VoIP network. I need a very detailed report, not just routers are up/down….more like MGCP/h323 reporting and monitoring registered devices in Cisco Call Manager.
Anyone out there recommend any good programs?
I was looking at Qovia, but they want about $100,000 for their solution
I’m willing to pay for good software but I would also like to pursue open-source if possible.
So I'm begining to wonder if there are SNMP MIBs / some way to use SNMP to monitor this ....some links I found:
ftp://ftp-sj.cisco.com/pub/mibs/supportlists/callmanager/callmanager-supportlist.html
ftp://ftp-sj.cisco.com/pub/mibs/oid/
Chris Serafin
IT Security / Cisco VoIP Engineer
chris@chrisserafin.com
1 REPLY
VIP Purple
Re: Cisco VoIP SNMP monitoring?
RTMT (Real Time Monitoring Tool) does some of what you want (such as devices registered, etc.) and ships with Callmanager. For higher end monitoring and reporting, take a look at Cisco Unified Operations Manager and NetIQ AppManager. As you said, you can also build your own monitoring solution using the SNMP MIBs.
RTMT
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00803fe70f.html
http://www.cisco.com/en/US/products/ps6535/index.html
NetIQ AppManager
http://www.netiq.com/products/am/modules/cisco.asp
Hope this helps. If so, please rate the post.
Brandon
911
