CiscoURLProxy max connections
Hi..!
I'm using the CiscoURLProxy COM, and works fine... but, when i send multiple request from differents ip phones.. the service die.
So, how many connections can i make with CiscoURLProxy?
Thnx in advanced
Re: CiscoURLProxy max connections
it will depend on your
windows 2000 pro = max 10 connection with IIS
there is also a known limitation of TCP connection with some windows xp
others services on the same machine ?
do you check the cpu usage while doing the test ?
Thanks for reply.
I'll check all that you say.
120
