11-28-2001 11:40 PM - edited 03-12-2019 01:32 PM
I have a customer with a "single subnet", voice and data on the native vlan. I configured the switchports for the phones for dot1p. But I want to send the Voice traffic coming from PSTN (E1-PRI) on COS=5. this is a little part of my config:
class-map VOIP-RTP
match ip precedence 5
policy-map VOIP-out
class VOIP-RTP
set cos 5
int fa0/0.1
service-policy output VOIP-out
dial-peer voice 1 voip
ip precedence 5
if I do a show policy-map int fa0/0.1 then I see that the class is matched, but the COS is not set!(that counter stays on 0)
So the voice traffic is send on tos=5 on L3, but I also want cos=5 on L2.
If we do this with voice and data on different subnets/vlans(not native) it's working good...
Has someone a idea? I appriciate any help.
Sascha Monteiro
11-29-2001 04:12 AM
Have you actually put an analyser on the network to check the 802.1 Headers. I have seen the counter stay at 0 but the packets were marked. Let me know what the Analyser states
11-29-2001 04:30 AM
Ok,
We don't have an analyzer, we have to use one from another department..... :-(
Thanks.
Sascha
11-30-2001 08:55 PM
Have you turned IP CEF on?
John
PS - What IOS are you using...?
12-04-2001 04:18 AM
Yes, ip cef is on.(without you can't set service-policy on the interface)
We are using 12.2(3), but have the same problem on a 12.1(5)YD4
Sascha
12-04-2001 05:43 AM
1) Interesting traffic must be CEF switched if you want mark it with 'set cos' under MQC
you can see it by 'sh int fx/x switching'
It seems to be a bug
CSCdv44860
12-04-2001 08:05 AM
Your config looks OK.
Does you Fast Ethernet port support 802.1Q/ISL?
As yo might know set cos is supported only with IEEE 802.1Q/ISL interfaces.
12-04-2001 11:39 PM
router: int fa0/0.2
encapsulation dot1q 2
switch: int fa0/1
switchport mode trunk
b.t.w. what should I see with sh int fx/x switching ?
Sascha
12-06-2001 08:07 AM
Why don't you paste the config, so we can look at it.
List the:
class-maps
policy-map and
ethernet subinterface config.
Cheers
12-07-2001 02:45 AM
Here is part of the config;
class-map match-all L3-to-L2_VOIP-RTP
class-map match-all L3-to_L2_VOIP-Cntrl
match ip dscp 26
policy-map output-L3-toL2
class L3-to-L2_VOIP-RTP
set cos 5
class L3-to_L2_VOIP-Cntrl
set cos 3
interface FastEthernet0/0.2
encapsulation dot1Q 2
ip address 10.10.50.211 255.255.255.0
ip policy route-map output-L3-toL2
service-policy output output-L3-toL2
dial-peer voice 3 voip
destination-pattern 356475...
translate-outgoing calling 1
session target ipv4:10.10.50.1
dtmf-relay h245-alphanumeric
codec g711ulaw
ip precedence 5
And when I look if they are set:
sh policy-map int fa0/0.2
FastEthernet0/0.2
Service-policy output: output-L3-toL2
Class-map: L3-to-L2_VOIP-RTP (match-all)
9808 packets, 3619143 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: ip precedence 5
QoS Set
cos 5
Packets marked 0
Class-map: L3-to_L2_VOIP-Cntrl (match-all)
0 packets, 0 bytes
Match: ip dscp 26
QoS Set
cos 3
Packets marked 0
Class-map: class-default
73173 packets, 4685304 bytes
Match: any
You see, the packets are matched on the class-map, but it looks like they are not set to 5!
Thanks for your help.
Sascha
12-07-2001 03:31 AM
By the way, CEF/Fast switched traffic counters not correctly shown in 'sh policy-map int ..'
'set cos' works for CEF-switched traffic only
And .. how can we see correct counter for packets marked with cos=5 ? This is question for TAC ;)
Hint: try 'ip route-cache policy' in configuration of FastEthernet0/0 and after that 'sh policy-map int f0/0.x'
12-07-2001 12:57 PM
First:
I don't see that you've created access lists, such as
access-list 100 permit udp any any
access-list 102 permit udp any any range 16384 32767
access-list 102 permit ip any any dscp ef
access-list 102 permit ip any any precedence critical
access-list 104 permit udp any any eq 2427
access-list 104 permit udp any eq 2427 any
access-list 104 permit ip any any dscp af31
access-list 104 permit ip any any precedence flash
access-list 105 permit tcp any any eq 1720
access-list 105 permit tcp any eq 1720 any
access-list 105 permit tcp any any range 11000 11999
access-list 105 permit tcp any range 11000 11999 any
access-list 105 permit ip any any dscp af31
access-list 105 permit ip any any precedence flash
access-list 106 permit tcp any any eq 2748
access-list 106 permit tcp any eq 2748 any
access-list 106 permit ip any any precedence critical
access-list 106 permit ip any any dscp ef
access-list 107 permit udp any range 16384 32767 any
access-list 107 permit ip any any precedence critical
access-list 107 permit ip any any dscp ef
access-list 108 permit ip any any
access-list 108 permit tcp any any
access-list 108 permit udp any any
You have to define what port groups each protocol uses, such as Voice traffic, Skinny, H.323 and/or MGCP.
Then you have to map the access list to the class-map and match the input interface.
Such as:
match access-group 102
match access-group 106
match input-interface FastEthernet0/0.2
match cos 3
Let me know if this helps.
12-10-2001 12:56 AM
Hi, I see 2x match access-group 106....Wich should be the other?
No, I dont have access-lists, because I am matching on IP-precedence 5 that I have set on the dial-peer.
That should work, I think.
Sascha
