Community Member
Clear ciso IP phones calls history centerally from the call manager
Hi guys
i have Call manager 6.1 with around 250 Cisco IP Phones 7941 and 7936 recently the corporate changes the extension plans and implemented new extension that caused the old extension history calls are still in phones i did not want to clear one by one from the phones i asked how to do it centrally or in bulk
Re: Clear ciso IP phones calls history centerally from the call
we do not have an interface or tool for that, you can simply shut down the switch ports to achieve this since the info is not saved if the phone has a power interruption
java
if this helps, please rate
java
www.cisco.com/go/pdi
You could send an ipphone execute with the following URI: Init:CallHistory
You should get the ip-addresses of your phones via axl risport, or use jtapi xsi to send the command.
this would work only on the 7941 however
Community Member
sorry from where can i execute this command
could you give me the full URL or which tools
312
