Client Matter Codes (CMC) - Speed Dials
We are running CallManager 4.1(3) with Client Matter Codes required for long distance calls for billing purposes.
The documentation does state that CMCs cannot be configured on speed dials but I noticed that if you dial the full string (phone number and CMC) while on hook and then press dial that it will work like that. I wondered if any knows a work around for this or if anyone knows if there is any plan to fix this problem.
We would like a way to add the CMC's to the end of the a speed dial.
Any ideas?
Pat
  • Other Collaboration Voice and Video Subjects
1 REPLY
Silver
Re: Client Matter Codes (CMC) - Speed Dials
You cannot configure authorization code or CMC for speed-dial buttons. You must enter the code when the system prompts you to do so.
112
