Cluster reload flow after new node adding
when I add new node (aka subsequent node aka subscriber) to the cluster
in which order it is better to reload the cluster. I'm interested in 2 scenarios.
1. x1 PUB, newly added 1st (first) SUB. Reboot server flow/order:
a) Restart SUB server
b) Wait until it will be up and running
c) Restart PUB server
2. x1 PUB, newly added 2nd (second) SUB. Reboot server flow/order:
a) Restart SUB server #2
c) Restart SUB server #1
d) Wait until it will be up and running
e) Restart PUB server
Please, advice, and correct, if needed.
Thank you in advance.
1 ACCEPTED SOLUTION
Re: Cluster reload flow after new node adding
1. not necessary
2. it's recommended and best practice to do it, to sync SDL layer
java
if this helps, please rate
java
www.cisco.com/go/pdi
cluster reboot order is based on CTI ID, you can find it under system -> Cisco Unified CM. click on a server, you'll get a different value per server. follow that order to reboot them. 1, 2, 3, etc
process is simple, start from node 1, reboot, wait until it fully comes up, then reboot node 2 and so on til you finish with all servers
java
java
Jaime,
Great explanation, thank you.
Let me, please, 2 (two) another questions.
1. Should I restart the whole cluster after changing security password by means of "Password Recovery" procedure ?
2. Should I restart the whole cluster after adding new subscriber node ?
1. not necessary
java
java
222
