Clustering Exchange 2000 and Unity 3.1x
emlee
I remember reading before that Unity only supported ACTIVE/PASSIVE clustering, but now the document reads that it does indeed support ACTIVE/ACTIVE clustering on Exchange. Is anyone running this successfully? Are there any pitfalls or anything to watch out for when using Unity in a clustered Exchange environment?
kechambe
Level 7
Level 7
I have Active/Active clustering running in the San Jose TAC lab. It’s basically the same as running Active/Passive as far as Unity is concerned. As long as you read the section of the install guide that covers how to setup Unity with an Exchange cluster you should be fine.
Keith
