cm 3.0, 2600 gatekeeper and netmeeting
Has anybody done this?
Netmeeting registers itselfs with a phone number
to the 2600 gatekeeper.
cm 3.0 registers also with the 2600 gatekeeper.
2600 gatekeeper provides dial plan information
for both netmeeting and cm 3.0
ip phones can call netmeeting and vice versa.
1 REPLY
Re: cm 3.0, 2600 gatekeeper and netmeeting
Yes, this is possible. You should check this URL for configuration information:
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/3_0/admin_gd/3_0_9/p6gatekp.htm
You will need to check the "Allow Anonymous Calls" box as well as the "Media Termination Point Required" checkbox in order for NetMeeting clients to function properly on calls between NetMeeting and CallManager through the Gatekeeper.
126
